Cooling fan never turns off, even though it's supposed to.
SixTwoSix
Post by SixTwoSix »
Fan / Cool: Loops 60, Inside 0, Cool 100
Fan Z: 1
Min Layer [S]: 10
Dwell Instead: No
Here are all the unique fan speeds found inside the gcode:
M106 S140
M106 S145
M106 S148
M106 S150
M106 S161
M106 S194
M106 S204
M106 S207
M106 S209
M106 S212
M106 S214
M106 S217
M106 S224
M106 S230
M106 S232
M106 S235
M106 S237
M106 S242
M106 S245
M106 S250
M106 S252
M106 S255
M106 S99
You will see M106 S0 doesn't appear anywhere, even once, even though Inside is set to 0.
This is confusing. I want the part cooling fans OFF when it's printing the inside, but they never turn off.
Also, I can't attach the gcode because the extension .gcode isn't allowed. So, here is an example of what it says:
; Blending Fan to Cool (54.7% blend)
; Blended Fan at 92%
; fan %*255
M106 S235
dadoblu_2000
Re: Cooling fan never turns off, even though it's supposed to.
Post by dadoblu_2000 »
in the print section you have selected and associated the m106(fan on) and m107(fan off) commands
Immagine 2024-05-26 010552.png (1.49 KiB) Viewed 3904 times
If you are still having issues, can you zip up the G-code file and attach the zip file to a post.
