System version: 11.0 Public Beta (20A5343j)
App version: KISSlicer_Mac64_v2_alpha_2.0.6
A small window pops up, blank, no text.
When you select anything from the menu, the application crashes.
macOS Big Sur
macOS Big Sur
- KISSlicer 2020-08-14 12-21-17.png (34.35 KiB) Viewed 13468 times
Re: macOS Big Sur
Yep. Seeing the same thing on released version of Big Sur now...
Re: macOS Big Sur
Yes, the Alpha v2 does not show most UI...
Re: macOS Big Sur
1.6 stable has the same problem with the UI
Re: macOS Big Sur
Does anyone know if this will get fixed? I just upgraded to Big Sur
Re: macOS Big Sur
Same here, just trying to reinstall on my clean install big sur... both stable and beta do not work anymore.
kind regards
Onno
kind regards
Onno
Re: macOS Big Sur
I have a m1 mac now so I have to use big sur and have the same issues
Re: macOS Big Sur
So guys, what is the result? there does not seem to be much in the way of support from KISSlicer.....not the best way to promote the program
Re: macOS Big Sur
Found a way to run KissSlicer on a new version of mac OS. Just use CrossOver and run the Windows version of Kiss. It works very well.
