Order of code generated
Posted: 18 Dec 2014, 19:12
I try to print a gear (From http://www.thingiverse.com/thing:328569 the item Gear_Reduction_Seconds_to_Minutes). In the 1.1 version, this worked fine, the perimeter like sections were printed first, then the insides.
In the beta versions, the slicer first does the code that fills in the little triangles in each gear-tooth, and then does the perimeter.
Unfortunatly my printer chokes on doing all those little blobs on an empty bed. The other way round were first an outline is done, and then the litte blobs inside each tooth are done, works.
Error or feature? Is the ordering of generated code for a layer non-determinsitic or is there a design intention here?
In general I thought perimeters are done before fill ?
