Sparse infill path
Hugues
Sparse infill path
Post by Hugues »
I have too much extrusion in the sparse infill path, when i look at the native BFB (without postprocessor) i don't understand why the spare infill path are calculated to get the double RPM of other path at the same speed ?
Is it a wrong parameter filled in kisslicer ?
Thanks !
regards,
Hugues
www.cubexupgrade.com
Ultim - Yoann
Re: Sparse infill path
Post by Ultim - Yoann »
I do not think that will be a problem of parameters but rather an internal problem in kisslicer that's why I change CuebitMod to reduce the rpm of M108 in the sparse infil pach.
However, it has always possibility of playing on the parameters to avoid the onset of sparse infill path
Look at viewtopic.php?f=20&t=72
Yoann
