I installed the latest beta 1.4.5.10, and cubeitmod 4.91 on Yosemite 10.10.1
When I hit SLICE, as soon as the slice process ends (yellow slice plane hits the top og the object), Ksslicer closes.
This is a part of Apple crash report:
Process: KISSlicer [2351]
Path: /Users/USER/Desktop/*/KISSlicer.app/Contents/MacOS/KISSlicer
Identifier: com.company.kisslicer
Version: 1.4.5.10
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: KISSlicer [2351]
User ID: 501
Date/Time: 2014-12-10 15:48:51.590 +0100
OS Version: Mac OS X 10.10.1 (14B25)
Report Version: 11
Anonymous UUID: 14EC7220-3ECC-A322-55C9-F8DF3FB3DFC7
Sleep/Wake UUID: 2596CCB9-732E-4B58-B37D-C3E82CC076C2
Time Awake Since Boot: 5700 seconds
Time Since Wake: 2300 seconds
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0xffffffffffffffd8
Any idea? How can I solve this?
Crashes Mac
Pgregory
Re: Crashes Mac
Does it do this with all models you slice?
Do you have an older version of KISSlicer to test - does it crash too?
Maybe try downloading it again - it could be a corrupt image.
Ros
Re: Crashes Mac
With version 1.4.4.4 I get: Failed, returning 512 with the same stl, and with others
With version 1.4.5.10 I didn't get an error, only application crash with Apple message about it.
Re-download didn't solve it
Ros
Re: Crashes Mac
Maybe... but when I hit downlad from the beta section on http://kisslicer.com/download.html and hit Mac32/64 downloads the 1.4.5.10Mikk36 wrote:Latest beta should be 1.5b1.17?
Mikk36
Re: Crashes Mac
If you manage to get to this subforum, maybe you can manage to look into the "KISSlicer 1.5 Beta 1 - in development" thread?Ros wrote:Maybe... but when I hit downlad from the beta section on http://kisslicer.com/download.html and hit Mac32/64 downloads the 1.4.5.10Mikk36 wrote:Latest beta should be 1.5b1.17?
Ros
Re: Crashes Mac
Ok Mikk I'll check there
martini
Re: Crashes Mac
Hi guys,
How do you make kisslicer + cubeitmod work on a mac? I can`t upload the language settings. I have a windows inside my mac where both work fine but it crashes when slicing larger files (probably my virtual windows is small but I don't know hot to fix that). I appreciate any help.
Re: Crashes Mac
I just posted a new Mac build to the Dropbox folder:
KISSlicer Dropbox Folder
Please let me know how it works!
Joanthan
Joanthan
Ros
Re: Crashes Mac
Hi the new Beta Slice stl without errors! Need to print the file to know if everything is ok.
thanks
thanks
