utenti/user cubepro here!!!!
hello if there are users cubepro? the new printer system of 3d .. understand where you are, if you have managed to remove the problem cartridge, there is some Italian audience, so I can understand my own language to which we find ourselves? I have already stressed too Giovanni! thanks a lot ! if by chance we opened an exclusive topic for the cube pro, because I understand the files are significantly different !!
Re: utenti/user cubepro here!!!!
I am doing some tests on the CubePro atm, relating to the cartridge usage, did you ever try to set negative parameteres on the cartridge count ? Try that, because if it works you will be able to use all the material you want with the same chip
