CubeItMod V 6.0 New Version !!!
Re: CubeItMod V 6.0 New Version !!!
Hi !
About filament humidity, i've the same setup as Peter with a monitor, i get the source from here : https://groups.google.com/forum/m/#!sea ... D2u1TUns8o
Cheers !
Cheers !
Yes, it becomes brittle with humidity. But it is not breaking during the print. It is breaking at the end of the print. I suspect the quick return to home once the scan is finished is having a sort of whip effect, and this is what is breaking the filament. I have printed about 10 items. All printed fine without the filament breaking during the print, but for 8 the filament was broken at the end of the print...
Giovanni V. wrote:The PLA filament is very sensitive to humidity that's why it breaks, if you don't dry it within a few days it could break during the print.
Interesting. I am wondering about a better setup for mine. I wondered about something with a roller to make sure the spool rotates nice and freely. Given my impression of the CubeX until Kisslicer+CubeItMod made it usable, a toilet roll holder sprang to mind...
Pgregory wrote:It is always fun to see how others modify their Cubex for overhead spools.
built a free-standing base out of plywood and 2x4's.
I used plastic waterproof containers to hold up to 3 spools and desiccant to keep humidity down.
I added an exhaust tube over the top of the printer to suck out any fumes.
It runs off the heated bed's aux power - it turns off when the print completes.
To reduce this effect you can print with a very low Perimeter speed, 10mm/s gives accurate printing on a Cubex Duo and don't check the option "Loops go from inside to perimeter"CJWubex wrote: and in fact the holes were just slightly rounded in the corners, which I assume is just a consequence of this sort of 3D printing. But all I had to do was round off the edges of the tabs just slightly to get them to slide in a bit, then a few taps of a hammer and it made for a nice solid joint.
Giovanni
Hi I have been using CubeItMod and KISSLICER for a while but I have been running V1.04 firmware on my CubeX trio so that I can use bulk filament. I now saw that you can use V1.07 with the new CubeItMod version 6.03, but when I try to run the cubeitmod on the file type i get a message saying "Speed Selection Error. All the MaxSpeeds into the Matl tabs must be 10mm/s or more faster than the other speeds (Perimeter, Loops, Solid, Support, Infill, Sparse Infill and Interface).
I have tried changing the values of the speeds but I keep geting this message and it is not working.
PLEASE HELP! What values do I need to change???
Please post sceen shots of : Ext Map tab, Printer / Speed tab, Matl tab for each material you have selected into the Ext Map tab, Printer G-Code/Prefix tab3DXtremes wrote: with the new CubeItMod version 6.03, but when I try to run the cubeitmod on the file type i get a message saying "Speed Selection Error. All the MaxSpeeds into the Matl tabs must be 10mm/s or more faster than the other speeds (Perimeter, Loops, Solid, Support, Infill, Sparse Infill and Interface).
- gastonfama
You have to check the speed setting in the Matl tab... ther you have a max speed setting that must be 10 or bigger than the speeds at the speed tab...3DXtremes wrote:"Speed Selection Error. All the MaxSpeeds into the Matl tabs must be 10mm/s or more faster than the other speeds (Perimeter, Loops, Solid, Support, Infill, Sparse Infill and Interface).
Hope this helps...
Got the same problem as well. I tried changing the max speed to 300mm/s, and even tried bumping the volumetric flow rate limit but I still have the same error.gastonfama wrote:You have to check the speed setting in the Matl tab... ther you have a max speed setting that must be 10 or bigger than the speeds at the speed tab...3DXtremes wrote:"Speed Selection Error. All the MaxSpeeds into the Matl tabs must be 10mm/s or more faster than the other speeds (Perimeter, Loops, Solid, Support, Infill, Sparse Infill and Interface).
Hope this helps...
I am running firmware 1.07 on the Cubex Duo, with Kisslicer 1.1.0 (64bit Windows) and CubeitMod603.
[quote="alexlevenko
[/quote]
CubeitModV6.xxx works only with Kisslicer V1.5, you can download it from the Dropbox link here on Kisslicertalk, I suggest you to use the Beta 1.20 or 1.22
[/quote]
I have the same error... work with KS 1.5 beta 1.17 CubeitMod V6.05 and even try with KS 1.5 beta 2.22
any ideas to solve that?
Many thanks!
Franck.
Many thanks!
Franck.
