Hello everybody.
I have a Cubex Trio and I am pretty new with the Kisslicer.
Does anybody have any experience with the Z-LIFT parameter?
As far as I know, it is supposed to lift the Z some mm while traveling. If I put the value in CERO the cubex still does some lift, and if I put something exaggerated like 5 mm, it lift a lot the nozzle. That makes me think that the parameter is working but...
Is there any way to disable the lift at all?
Thank you very much.
Regards.
Z Lift in Cubex Trio
- gastonfama
Re: Z Lift in Cubex Trio
Hello everybody.
I finally found out that the option Z-Settle in Printer / Hardware also affects that behavior.
Solved.
Solved.
Hello,
it's been a while since this thread but has anyone managed to deactivate Z-lift on CubeX-bfb firmware?
Regards,
George
Regards,
George
