Hello,
I'm using a Cube Pro Trio and Kisslicer 1.5 Beta (Pro) and Cubeltmod491. I tried mulit color prints, but still have two problems:
1.
After a layer is printed, the extruder stays for a while until it moves to the "Jet Wiper Assembly" (should move directly to the Jet Wiper Assembly) .
2.
When the second extruder returns from the Jet Wiper Assembly it sill have some useless Filament on it, which runins the printing quality.
Does anyone has a solution for it? (G-Code)
Thanks for reading!
Multi Color Print | CubePro Trio | Kiss 1.5 Beta 1
Re: Multi Color Print | CubePro Trio | Kiss 1.5 Beta 1
OK. Just fixed it with some G-Code (coordinates). But the tool changing still takes forever...
Does someone has an idea to make the changing faster for multi color printing?
- gastonfama
I am also working on the same. If I have any progress I will let you know.
Regards
Regards
Thanks!
A target whould be, that all used extruders are heated up and cleaned at the Wiper Assembly first. After this they should be kept warm the hole print. After a maximum time period or even after every layer all extruders should be used at a pillar or something to guarantee a clean print.
If M<EXT+1>04 S<Temp> is my only code for "select Extruder" and using a "keep-warm" temperature of 245 (ABS) it still take like 35 sec for tool changing
