filament use by length not volume
Posted: 22 Nov 2014, 11:29
by frozen.rabbit
I would still like to see filament use by length instead of volume in print estimate.
Re: filament use by length not volume
Posted: 22 Nov 2014, 18:52
by abuharsky
frozen.rabbit wrote:I would still like to see filament use by length instead of volume in print estimate.
+1
Posted: 24 Nov 2014, 02:00
by Garry Bartsch
+1
Or both?
Add weight (was Re: filament use by length not volume)
Posted: 25 Nov 2014, 07:44
by 3dwim
I use weight. That is, I know the relative weight of 1 cm^3 of the filament I use and I've put that parameter instead of the price. I do this because I don't want to run out of filament durin a night of printing just because I'm a little bit short on the spool at hand. To do a proper estimate I first put the spool on a balance, substract the weight of the spool itself and when needed I can change before starting the print. I sleep much better now.
So we probably want several (configurable) fields for cm^3, weight, length and price.
Posted: 26 Dec 2014, 04:59
by Srek
If i had to choose between the two i would choose volume. It is basicaly the single property that makes all the different materials comparable. I hope that Filament manufacturers will pick this up and put the volume alongside the weight or length of a spool.
Posted: 26 Dec 2014, 13:27
by Dreide
For 1.75mm filament I put 41.57517 ($/cm^3) in the "CostCalc" field (Material tab), which gives me the filament length in cm.
[41.57517 = 100/(piĀ·(1.75/2)^2)]
Posted: 03 Jan 2015, 09:42
by GeckospotNixie
Outstanding Dreide!
Thanks for the tip!
