Kisslicer installation on mac pro
Posted: 20 Nov 2023, 14:03
by dadoblu_2000
Quick information, they gave me a Mac Pro with iOS Sierra 10.12.6 (16G2136) I tried to download KS, I encounter a problem during the installation, the error message tells me that the system is not supported, could you tell me which version of iOS Is it necessary or are there shortcuts that need to be taken?
Re: Kisslicer installation on mac pro
Posted: 21 Nov 2023, 08:33
Question asked - awaiting response.
EDIT:
Apparently, that is an old OS, but it is being looked into.
Posted: 13 Dec 2023, 13:29
by dadoblu_2000
ok I updated a more modern version of iOS in order to make kisslicer work, but now I don't understand where the folders relating to kisslicer configurations are saved, every time I close it and restart it it asks me to insert the relevant profiles and I have to reconfigure everything again, any ideas to suggest?
Posted: 05 Jan 2024, 12:33
Hi. Sorry for the late reply.
This is the answer I have received:
The profiles are behave the same-ish way they do on Windows...in folders right next to the executable. But on Mac the executable is in an "app bundle", which is actually just a folder structure.
So in the same directory where the kisslicer.app is found, you should also find the _profiles subdirectories.
You can also start KISSlicer with a command line option -inidir "directory", if you want to specify where you put them.
This lets you use different sets of profiles
