Please note that these profiles have been created using firmware V4.7
Although the profiles have been tested and work well for me, please use them with care and understand that they are supplied for use at your own risk.
IMPORTANT NOTE: In order for these profiles to work, you will need to download and use at least version 23.07 of Kisslicer. DO NOT attempt to use these profiles with earlier versions.
The Prusa XL firmware (almost) correctly implements arcs (G2/G3) and these profiles are set to use arcs whenever possible. The Kisslicer arc generation works very well and allows models created using simple design software (i.e. Tinkercad) to be printed with smooth cylinders, rather than faceted sides. Note that small arcs may suffer some stuttering/noise, but will generally print fine.
The profiles are all set to use a 0.6mm nozzle. The purge tower should be enabled for all support types as this is used as the initial purge instead of the front of the bed.
Prusa XL Multi Profiles
- Kisslicer Prusa XL Multi Profiles.zip
- (19.54 KiB) Downloaded 747 times
