allow "extruder clearance (radius)" to accept negative value
Isaac_alaska
Post by Isaac_alaska »
it would be nice if the extruder clearance box accepted negative values, i use this for sequential printing of round objects, and even with zero in the box they are still spaced farther apart than necessary. is it a simple change to allow negative values to work here? obviously this would be a "use at your own risk" feature
