Micro-Travel Moves within Infill (cause Preload action)
McNugget6750
Post by McNugget6750 »
I'm calibrating my extruder. I encountered an issue on Kisslicer Pro v2 a 2.0.6 Win64 where dense infill to support a skin layer is separated into tiny separate moves that each cause PreloadVE action!
This is insanely slow, extremely inefficient and not needed. At least, I can't figure out a reason why this would be useful.
Earlier versions would print continuous zick-zack patterns with one start and one end. Current versions don't do that.
Micro Travels 2.JPG (86.69 KiB) Viewed 3742 times
Micro Travels 3.JPG (106.27 KiB) Viewed 3742 times
Micro Travels 1.JPG (99.7 KiB) Viewed 3742 times
Every white line is a travel move. Most of the green lines are completely separate. This should not be necessary.
