V2-alpha Travel settings "Stay Inside" and "Avoid Edges" do not work.
Re: V2-alpha Travel settings "Stay Inside" and "Avoid Edges" do not work.
I was wrong. I've confirmed that "Avoid Edges" does make a huge difference. It does miss some edge crossings and the choice of seam angle affects the result but, at the best angle selection, the difference is well worth getting V2-Alpha!
I did have to use Rep-Host to evaluate the different paths produced, however, because the Kisslicer graphic doesn't seem to display them.
If Jitter is non-zero, "Avoid Edges" and "Stay Inside" sometimes do not work. Use Rep-Host (not the KISSlicer graphics) to investigate.
