Need Finetune.stl help pls
Posted: 12 Jan 2020, 17:23
I'm new to 3D printing. Came across a working Cubex Duo and have been going through the paces of overcoming it's shortcomings. Recently busted up my cartridges trying unstick the dumb cardboard spool and have come to kisslicer and cubeitmod to get by the broken chip and use other filament. Previously I was able to successfully print a few items. I think I'm sitting at a 10% success rate.
Now, I have yet to successfully print with kisslicer and cubeitmod. First had trouble getting the first layer to stick to the pad (an ongoing issue of mine). I tried printing a finetune.stl so I could get some help from you all. Below are the respective files.
The grossly messed up side of the finetune pick is where it decided to just get all messed up on the hot end and come loose from the print bed at the same time.
The slightly smoother side is print bed side.
I would greatly appreciate anyone's help in figuring out what my issues are. Attached is the bfb and bfb bak in a zip
