How is purge octagon properly used? If I use it, the "tower" is always partially empty (some layers are not printed if in the layer is not material change) ... this is a problem (practically unusable). Where am I making mistake?
Tom
Purge octagon
Re: Purge octagon
On layers where there is no filament change, the tower should still be printed with the filament in use, but as a very sparse layer.
Please slice a model where your issue happens, zip up the G-code file and upload it here.
