Page 1 of 2
KISSlicer crashes on initial startup
Posted: 02 Mar 2015, 17:12
by Muggs828
Hello All,
Just like the subject says, When I run KISSlicer I get an immediate crash.
Win 7 64 SP1
I thought that because I was trying to run it from an external drive that that was the problem, but I get the same result from my desktop.
TIA,
Muggs
Re: KISSlicer crashes on initial startup
Posted: 02 Mar 2015, 18:19
by Mikk36
What version?
Posted: 02 Mar 2015, 19:33
by Muggs828
DUH! Sorry. 1.1.0 the "stable" one.
Posted: 03 Mar 2015, 02:36
by Mikk36
Could you also see, if the newer builds crash for you?
viewtopic.php?f=6&t=362
Posted: 03 Mar 2015, 08:32
by Muggs828
Nope! Bang, crash right away!
KISSlicer_Win64_1.5beta2.16
I'll try others next.
Thanks,
Muggs
Posted: 03 Mar 2015, 11:06
by Muggs828
No Joy for any of the beta version either!
Here are some screen shots of Windows Event Viewer:
https://app.box.com/s/5e1oc7tbw74ayw82kqp9xms08a73oc0w
If I try to run from external drive, BAM instant crash. If I try to run from desktop, it hangs forever (I waited 15 minutes).
It has to be something with my configuration because everyone else seems to be able to run the program.
Posted: 03 Mar 2015, 11:28
by Muggs828
I just tried both stable version 1.1.0 as well as 1.5beta2.16 and both worked flawlessly on my laptop.
SO, after now having a look at the UI, I can see that it's probably a graphics issue, as I never get a "view" in the graphics box before my crash.
Graphics card is AMD FirePro V4900 if that helps.
Posted: 03 Mar 2015, 16:42
by Dreide
Muggs828 wrote:Graphics card is AMD FirePro V4900 if that helps.
I observed something similar with a FirePro V4800 a while ago. In the course of trying to solve a completely unrelated problem, I installed different graphics driver versions and used the opportunity to also check KISSlicer's behavior.
KISSlicer worked with:
* Win64/v8.911.3.3 (certified [=WHQL?])
* Win64/v13.352.1014 (Retail End User)
It did not work with (crash/hang):
* Win64/v12.104.2 (WHQL)
* Win64/v13.152.4 (WHQL)
* Win64/v14.200.0.0 (beta/RC)
Posted: 03 Mar 2015, 16:55
by Muggs828
Dreide,
Thanks! That's great information. I'll try that tomorrow morning.
Posted: 04 Mar 2015, 12:52
by Muggs828
OK, I tried many different FirePro V4900 drivers to no avail!
I'm out!
