How to setup dual extruder printer with different nozzle dia
Posted: 24 Feb 2015, 16:21
Hi all!
I want to use my dual extruder with 0.35mm in one extruder and 0.5 in the other one.
In the rare cases I need to print with both I would use one for support or different material type (flexible and PLA for example).
The only parameter I found I could adjust is Extruder Gain (seems to be used for different Gear ratios or so).
Did anybody use it already to compensate for different extruder sizes and is my assumption right that r² ratios (0.35/2)²/(0.5/2)² = 0.49 would be the gain of the extruder of the 0.5 nozzle if 1 is the gain for the 0.35 nozzle?
p.s.: I know that I can setup different printers for printing only on one or the other extduders 'in single mode'. This is what I am doing already when one of the extruders is 'in repair'.
Thanks for any thelp
Frank
Frank
