Minimum path length
Minimum path length
It would be great if one could suppress the extrusion of very small paths that otherwise would require extra travel moves. This would be like Simplify 3D's "Minimum infill length", which BTW is also applied to loops.
- Davide Ardizzoia
Re: Minimum path length
Crowning setting should be already doing this.
Brgds
Davide
Brgds
Davide
Yes, this is true for short crowning paths. But short paths which appear already when crowning is switched off (-1) are still printed when crowning is on, even if the crowning threshold is high.Davide Ardizzoia wrote:Crowning setting should be already doing this.
I thought crowning paths are "any"short segment path that requires a travel move. If this is the case and you are seeing extrusion paths shorter than your crowning setting then there is a bug somewhere .
