Spiral Vase
Posted: 30 Jan 2015, 20:53
by 626Pilot
The one thing I can't do with KISSlicer is print spiral vases. I have to use slic3r for that, which is a pain because slic3r takes AGES to do anything.
The idea is pretty simple. You print the first layer normally. After that, the hot end is moved around in a slowly climbing spiral, so rather than print layer-lift-print layer-lift, it's just one long strand of filament going all the way up. You get no seams or retraction side-effects anywhere. This is useful for printing single-wall vases, especially with T-GLASE.
Re: Spiral Vase
Posted: 02 Feb 2015, 06:46
by SonnyToft
Under the Style tab.
Pull the Infill slider all the way to the right, then it will change to Vase.
Rgs
Sonny
Re: Spiral Vase
Posted: 02 Feb 2015, 10:22
by mhackney
+1 on 626Pilot's request plus an addition...
Sonny, KISS' Vase style does not do a continuous spiral, it prints each layer one at a time with a new beginning and end on each layer. 6s6Pilot's request is for a continuous helical bead with one start at the base and an end at the top of the part. This will be even more powerful with new hotends like E3D-Systems' Volcano which is designed to print large nozzles (.8mm etc). Large vases with a Volcano will be fast to print, strong and look fantastic with no seam line!
Now my addition...
I'd also like a spiral fill option for shell layers (top and bottom). My 3D printed fly reel is a perfect example of where this would be useful.
Cheers,
Michael
Re: Spiral Vase
Posted: 03 Feb 2015, 02:44
by SonnyToft
I actually thought vase was doing the right spiral thing.
My mistake.
Forget everything is wrote.
Rgs
Sonny
Re: Spiral Vase
Posted: 16 Jul 2016, 13:12
by Ronin
Hello!
Any news about Spiral Vase? Have to use Slic3r for that =(
Re: Spiral Vase
Posted: 13 Apr 2017, 01:40
by brasshopper
Cura also does a "real" vase mode. Not that I see that as helpful here, just an alternative to using SLIC3R to get a spiral vase mode. At least one other slicer I have tried, CraftWare, fails to have a real vase mode.
