Large hollow thin walled object rocking back an forth
Posted: 17 Nov 2014, 15:45
I am printing a case 8 inch wide x 5 inch deep x 6 inch tall.
The wall thickness it 0.1 inch.
The face on the bottom has two rectangular view ports.
Since there is not a lot of surface area on the bottom, I added a 6mm brim.
The body prints at an angle sloping to the back of the printer. The sides are parallel to the printer.
As the body prints, the print head is either dragging or pulling on the body.
As the print gets taller, the drag or pull gets amplified on the base and eventually pulls the base off the heated bed.
If I increase the thickness of the sides to 0.3 inches, this appears to make the object much more solid and sturdy.
It does not get pulled or rocked as it prints and stays stuck to the bed.
Or, the solid infill is not filled by tight zig-zag lines and does not cause the print head to push the part around.
My question is: how much drag / pushing can you expect from the print head?
Should it not exert horizontal forces on the print while it prints?
I suspect my problem is with over-extrusion on the zig-zag filling, causing the print head to push the part around while printing.
Do any of you have issues with the print head exerting horizontal pressure on the part?
