Default 1.75mm PLA Settings for Cubex Trio ??
chrisrwhite
Post by chrisrwhite »
Can anyone please help with default kisslicer settings for 1.75mm PLA for the Cubex Trio???
Chris
Pgregory
Re: Default 1.75mm PLA Settings for Cubex Trio ??
Post by Pgregory »
That depends on what 1.75mm filament you have.
Who is the manufacturer? Each manufacturer has different print temperature range settings.
Is it really 1.75mm? Use a caliper to test the average diameter of the filament from several places.
You will need to know the average diameter for KISSlicer to determine flow rate.
chrisrwhite
Not sure who is the manufacturer. Purchased in bulk off ebay. It is 1.75mm in diameter.
Miguel_FL
Post by Miguel_FL »
1'75 it's nominal or real (average) diameter?
I usually let flow the PLA filament at 205ºC and 3 rpm, and play with the temp until begin to clog, to find the minimum temperature, then I increase in 5ºC the main and 10ºC for the first layer.
Check the flow with the calibration box and adjust the flow tweak.
3DS CubeX Duo
Kisslicer Pro user
