To run CubitMod, I believe that you will have to be running KISS V1.5 (although 1.6 may be OK) as this program relies on KISS comments to operate.
As for the Post Process command, please try formatting as follows:
""Cubeitmod.exe" "<FILE>""
Note that both program and file have double-quotes, as does the whole string - 3 pairs in total.
new cubex duo suffer... user
Re: new cubex duo suffer... user
Sorry, I have never used CubeitMod, so I don't know what the errors relate to.
Maybe someone else will be able to help.
No. Prusa "originals" Mk2+MMU and Mk3+MMU2GVi wrote:Are you running it on the 3d systems software? If so whats the cost ?
https://shop.prusa3d.com/en/17-3d-printersGVi wrote:could you enplane that a little more plz?
I have owned one Chinese Prusa i3 clone and moved on to the "originals" when Josef Prusa started selling printers. Started with the Mk1, then the Mk2 and upgraded the Mk1 to Mk2 and added their 4-filament MMU to both. I was then sent the Mk3 with their 5-filament MMU for beta-testing.
Now PR has just announced their new Mini with a Maxi in development.
PR printers generally tend to be considered by most users as good value-for-money, with good support and upgrade-ability , however their MMU units are a bit hit-and-miss - they work for some and fail for others.
Hi,GVi wrote:im really getting nowhere with this i think i will probably get a new one as these cubex ones are more hassle than its worth
use Kisslicer 1.5 Beta 2.20 with Cubeitmod 6.05.
Cubeitmod use the comments into the Kisslicer file to change the parameters, the 1.6 and newer versions of Kisslicer has differents comments and Cubeitmod can't work with them.
Cubeitmod can work with other 1.5 versions of Kisslicer, but the Beta 2.20 is the best.
Usually if you install Kisslicer 1.5 and Cubeitmod 6.05 following the instructions here :
viewtopic.php?f=20&t=1238
it will work without problems.
I've stopped the Cubeitmod's development because I changed hardware on my Cubex, now I run a Marlin Firmware.
Good luck.
Giovanni
