Hello,
When I loading the STL file below, I got a crash.
The stl culprit :
Tested on KISS 1.6.3 / KISS 2 0.9.9 / KISS 2 1.4.8 (OS X).
Can anybody try this file on other platforms?
Thank you,
[SOLVE] Kisslicer crash when loading specific STL file
Re: [BUG] Kisslicer crash when loading specific STL file
Loads without issue on Windows, 2a148 both 32 and 64 bit.
I have also printed this model with a previous version of KISS, but I don't remember which version other than Win64)
- ksh_germany
I tested that stl too, no Problem on Windows 10 64Bit, and 2 other pc's.
Greetings from Germany
Beantworte fragen zu Kisslicer auf deutsch
Alright,
Os X specific bug with 10.14.6, seem OK on 10.11.6.
Thank you,
Thank you,
There's a new release in the Dropbox: V2a1.5.2 which should fix this issue.
I try the alpha V2a1.5.2 and got the same problem with oS X 10.14.6.
However please take in consideration that I don't create any profile on this new version.
I only cancel the wizards before drag and drop the STL file.
Jonathan is working on this.
However, if you repair the model with NetFabb, it loads fine.
- overhang_test (repaired).zip
- (56.05 KiB) Downloaded 241 times
Thank you, I just submitting the bug, I'm not in a rush to use the stl.
However, thank to share the news concerning Netfab.
V2a1.5.4 is now available.
Can you please test to see if it fixes the problem.
Same result with the STL, the Drag and Drop, Open and Preview generate infinite loop processing.
I also confirm that the repaired version open / preview correctly.
By the way, the new V2a1.5.4 automatically get my old profiles, so no wizard please do everything another time, that a good thing.
