Hi all,
should I set the drvlen parameter for titan extruder in direct mode or it's not necessary?
drvlen with direct extruder
Re: drvlen with direct extruder
DrvLen is the distance between the drive gears and the tip of the nozzle, so I guess in your case it would be around 50mm.
