Kisslicer from command line on windows
Postby masterofreality » 25 Jun 2019, 02:10
Hello.
I'm using Kisslicer for automation slicing process of 3d printing small factory.
I Run kisslicer from console in windows from external application service. (with -hidegui and etc arguments )
Please! Tell me, How can i ignore this message programmaticaly (without pressing the button) for ex. is there are settings or any workaround ?
Thank you
masterofreality
Re: Kisslicer from command line on windows
Postby pjr » 25 Jun 2019, 02:43
Could you not simply open the Settings/Misc tab and increase the RAM Warning to something more sensible?
Postby masterofreality » 25 Jun 2019, 03:09
Unfortunately no (
Because if RAM warning value more than real RAM , this value is igonring. I was thinking that in nogui mode should not be any windows.
Or May be can set this value in config file?
masterofreality
Postby pjr » 25 Jun 2019, 09:44
masterofreality wrote:Unfortunately no (
Yeah, I thought that may be the case. Just checking. Hopefully I will have a response shortly.
Postby pjr » 24 Jul 2019, 10:45
This is now on the fault list and will be included in a future release.
Return to Troubleshooting
Users browsing this forum: MSN [Bot] and 1 guest
