Cube X Duo (Can I Use PVA) *NEWB HELP*
skylerporter2112
Post by skylerporter2112 »
Hey guys,
I'm new to this and although I have been printing for a bit with my Cube X Duo I am new to kisslicer. I am wondering if any of you have experience with these if it is possible to print with PVA for supports with this printer? I would really like to cause I work for a school that has these and getting a completely new printer for this isn't possible. Help and any information would be great honestly. Thanks!!!
Re: Cube X Duo (Can I Use PVA) *NEWB HELP*
Yes, it is. You will need the PRO version to print with multiple extruders.
On the Settings/Ext Map window, in the bottom right area, you select your PVA extruder in the "Interface Ext" box and leave everything else set to the other extruder.
This will print the support in the regular material and the support interface (the 3-or-so layers between the support and the model) in PVA
