Hi to all,
is it possible to reload a gcode file created in the past and see what objects does it contains?
Or I must to reload stl files?
Reload gcode
Re: Reload gcode
No, you can use a G-code viewer for this.
I use Craftware to view G-code files; it is an excellent tool for this.
KISS is only able to read the settings used to slice the model from the G-code.
Re: Reload gcode
Many thanks Peter.pjr wrote:No, you can use a G-code viewer for this.
Alex.
Re: Reload gcode
just downloaded it - looks good. Thanks for this, filled a gap in my toolset (currently use blender, meshmixer, kisslicer and now craftware - would be good to have an end-to-end workflow in one software, but for free software this is an amazing set of tools)pjr wrote:No, you can use a G-code viewer for this.
