Hi all.
I have a lot of problems with ABS filament ;(. It always delaminated, even if first layer have good adhesive. Simple enclosure don't solve this problem too. I found information about thin wall (that printed around model like skirt but at full height) thats helps to solve problems with ABS. Is it possible to add such wall with KS?
Add thin wall around the model.
Re: Add thin wall around the model.
Under "Support", "Prime / Skirt / Pillar / Wall" , select "Wall (all layers)".
Dreide wrote:Under "Support", "Prime / Skirt / Pillar / Wall" , select "Wall (all layers)".
There is no latest build for Mac with that functionality.
