Selective Support Generation?
Is there a way to tell Kisslicer to only generate supports under overhangs over a certain size? In the attached images, I want to have support in the areas outlined in blue, but no support in the areas in red. I have printed this part before using a Slic3r and was able to do this, but I don't remember what settings I used and I want to use Kisslicer's features such as the preload setting. The hexagonal holes print fine without support, but I would like the blue outlines areas to have support even though they technically don't need them.
Re: Selective Support Generation?
Not currently possible. Best solution is to use MeshMixer to add the required supports and then use KISS without.
