KISSlicer V2.0 Alpha Fault Reports
Postby pjr » 10 Jul 2018, 16:00
Please post any fault/bug reports in this thread and I will combine them in this post.
Please include in your report the project file and (simple) model which exhibits the problem.
And please, check that the fault has not already been reported...
Many thanks for your help with this.
Reported so far:
When Cool-Purge is set to zero, the purge tower is only printed on layers containing a tool change.
Non-simple travel moves shows some moves as printing moves in Paths preview
Prime pillar sometimes positioned on model
Postby hacker » 13 Jul 2018, 03:41
Also displaying travel moment as print moves in path preview? It doesn't seem to affect the "Simple" travel mode, so I can imagine this was added for debugging purposes, but probably needs to be amended to display as thinner lines at least?
P.S. What is (or will be) "3D Scan Profile"?
Postby pjr » 13 Jul 2018, 07:02
hacker wrote:Also displaying travel moment as print moves in path preview? It doesn't seem to affect the "Simple" travel mode, so I can imagine this was added for debugging purposes, but probably needs to be amended to display as thinner lines at least?
Sorry, I do have that on the "internal" list; didn't add it to this one. Apologies...
hacker wrote:P.S. What is (or will be) "3D Scan Profile"?
No idea. Where have you seen that???
Postby hacker » 13 Jul 2018, 10:41
No problem, just wanted to make sure it gets somewhere. And probably it would make sense to have it here so that it's not reported again.
The "3D Scan Profile" is the third item in the right-click menu on the model. Below "Add Dynamic Denisty Map(s) Images" and above "Revert to original height". (which makes me think that some uniformity in the case of menu items would make the menu prettier:)).
Postby hacker » 19 Jul 2018, 08:36
Sometimes this happens:
Project and stuff attached. I'm not sure how reliably it is reproducible, sometimes I just change some minor bit and it places things better.
At any rate it's nice to see how gracefully it handles this placement ;-)
testholes.zip
(33.05 KiB) Downloaded 46 times
Postby hacker » 26 Jul 2018, 13:57
Not sure if it's a bug or I'm getting something wrong. I thought "open base" makes vase bottomless, am I wrong to think so? Because if I'm wrong, I think I need some explanation what it means and if I'm right I think it either doesn't work or doesn't always work :)
Postby hacker » 02 Aug 2018, 17:29
1. It seems like when printing raft and purge octagon the first layer of purge octagon isn't printed and so it doesn't stick well to the build plate.
2. Maybe it would make sense to stop printing the purge octagon after the last filament change? (though I'm sure it's on the "internal list" already).
Postby pjr » 03 Aug 2018, 03:26
hacker wrote:2. Maybe it would make sense to stop printing the purge octagon after the last filament change? (though I'm sure it's on the "internal list" already).
Yes, that's on the list; it's there for the final unload, but there are other methods.
Postby hacker » 06 Aug 2018, 12:12
"reload from file" seems to misplace the model, just offset it a bit (not sure if it's consistent, but it's just been offset by approx 20-30mm towards the front).
Postby pjr » 06 Aug 2018, 13:53
hacker wrote:"reload from file" seems to misplace the model, just offset it a bit (not sure if it's consistent, but it's just been offset by approx 20-30mm towards the front).
Thanks. Added to Jonathan's list.
Next
Return to Alpha release talk
cron
