ZGap won't work
ZGap won't work
Postby Acmeman76 » 06 Jul 2018, 08:33
Hi all
i've an issue with KIssslicer 1.6.3: i can't setting up the zgap trough the gcode generation, as you can see in the image i've set zgap 0.2 but no space in the 3d model neither in 2d.
What's wrong?
Greetings
Acmeman76
Re: ZGap won't work
Postby pjr » 10 Jul 2018, 13:35
So, the support layer heights are adjusted during export and not visible in the views after slicing.
When the G-code is exported, the Z-gap is present and is a value between 0 and 90% of current layer height (adaptive layers).
Re: ZGap won't work
Postby sinned6915 » 12 Jul 2018, 10:45
is the value for Zgap in % or absolute millimters?
what is the difference between the settings for "1st Zgap" and "Zgap". where might there be a Zgap that is not 1st?
tia
dennis
sinned6915
Re: ZGap won't work
Postby pjr » 13 Jul 2018, 02:53
1st Z-gap is for the raft; Z-gap is for the support interface
Re: ZGap won't work
Postby woody3dp » 29 Aug 2018, 01:38
pjr wrote:So, the support layer heights are adjusted during export and not visible in the views after slicing.
- Does it work the same way for fixed layer (I often print with fixed layer for the moment) ?
- Is there a way to bypass this value, because my support fuses to my object, it's very difficult to remove the support without damaging the object.
thanks
woody3dp
Re: ZGap won't work
Postby pjr » 29 Aug 2018, 02:36
woody3dp wrote:- Does it work the same way for fixed layer (I often print with fixed layer for the moment) ?
thanks
This has been added to the fault list:
Z-gap. Must be according to set value irrespective of layer height and must be able to be viewed after slicing.
Re: ZGap won't work
Postby woody3dp » 29 Aug 2018, 04:59
That's a good new. Thank you for taking your time to answer Peter.
woody3dp
Return to Troubleshooting
Users browsing this forum: No registered users and 3 guests
