Hi all-
Here is an knurled nut object that I generated in OpenSCAD and sliced in KS.
Some of the slice errors I understand are from the way that the mesh was generated. But I am getting confused by the path colors- where it seems that it is putting a crown path. The unsupported section tinting makes sense since its is building the knurl segments out from the walls.
What are all those magenta traverses and blotches at the ends of those path triangles? I was expecting more consistent infills and loops.
Dennis
Help me understand the color codes
- Thumbwheels.7z
- OpenSCAD source and stl in a 7zip container
- (166.29 KiB) Downloaded 109 times
Re: Help me understand the color codes
Hey! Sorry for the late reply, but what you are seeing is a bug that is brought on whenever there's an error in the mesh. Jonathan is aware of the problem and will be releasing an update to fix that bug soon.
Thanks for the reply!
