The nozzle of the printer goes at the start from the home position into the bed. Even after the bed levelling and Z-offset procedure. G-codes ware generated with the latest Kisslicer in pro version. What was not good defined or could be the conflict between the machine codes and the wizard created on the Kisslicer?
Can anyone tell me why the generated G-code from Kisslicer pushed the nozzle in the bed, before the start of printing? Atom printer is a delta type printer.
Here is the profile code:
[ATOM2504]
bed_STL_filename=/Applications/KISSLICER16/ATOM.stl
MRU_style=ROUND NORMAL
MRU_support=STANDARD SUPPORT
MRU_material=PLA
extension=gcode
cost_per_hour=0
g_code_prefix=3B205B6D6D5D206D6F64650A4732310A3B204162736F6C75746520706F736974696F6E206D6F64650A4739300A3B2052656C6174697665204578747275646572206D6F64650A4D38330A3B2053746172742068656174696E6720746865204265640A4D31343020533C4245443E0A3B20486F6D652074686520617865730A4732380A3B20576169742074696C6C2074686520426564206973206865617465640A4D31393020533C4245443E0A3B20486561746564206368616D62657220472D636F6465206973206E6F7420756E6976657273616C0A3B4D31343120533C424F583E0A3B4D31393120533C424F583E0A
g_code_preheat=3B20686561742074686520286E6578742C207468656E2063757272656E742920657874727564657220776974686F75742077616974696E670A3B4D31303420533C54454D503E20543C4558542B303E0A3B20556E636F6D6D656E74207468652070726576696F7573206C696E6520746F20656E61626C6520707265686561740A
g_code_warm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
g_code_same_warm=3B204D6F766520746F20746865207374617274206F6620746865206E65787420706174680A473120583C4E455854583E20593C4E455854593E2046363030300A47342050300A3B2053616D652065787472756465722C207761726D20616E6420776169740A4D31303420533C54454D503E0A4D31303920533C54454D503E
g_code_same_cool=3B2053616D652065787472756465722C20636F6F6C20286E6F2077616974290A47342050300A4D31303420533C54454D503E0A
g_code_cool=3B2053616D652065787472756465722C2061626F757420746F20646573656C6563742C206D617962652072657472616374206265666F726520636F6F6C696E6720646F776E0A3B2052455452414354204845524520494620594F552057414E540A47342050300A4D31303420533C54454D503E0A
g_code_N_layers=NULL
g_code_postfix=3B20416C6C206578747275646572732061726520726574697265640A3B204D6F7665207468652068656164207570202F2062656420646F776E0A4739310A4731205A2B31300A4739300A3B207475726E206F666620746865206265642026206368616D62657220286D616368696E65207370656369666963290A4D3134302053300A3B4D3134312053300A3B2046494C4C205448495320494E204153204E4545444544
g_code_pause=3B205061757365207468656E20526573756D650A3B20757375616C6C79204D3020287479706963616C29206F72204D3120286C65737320636F6D6D6F6E29206F72204D32323620286C6561737420706F727461626C65290A4D300A
every_N_layers=0
post_process=NULL
num_extruders=2
firmware_type=1
add_comments=1
g4p_uses_seconds=0
fan_on=M106
fan_off=M107
fan_pwm=1
add_m101_g10=0
z_speed_mm_per_s=150
z_settle_mm=0
bed_size_x_mm=220
bed_size_y_mm=220
bed_size_z_mm=320
ext_radius=0
bed_offset_x_mm=0
bed_offset_y_mm=0
bed_offset_z_mm=0
bed_roughness_mm=0
round_bed=1
travel_speed_mm_per_s=150
rim_speed_mm_per_s=150
first_layer_speed_mm_per_s=15
dmax_per_layer_mm_per_s=15
xy_accel_mm_per_s_per_s=800
xy_steps_per_mm=200
lo_speed_perim_mm_per_s=5
lo_speed_loops_mm_per_s=10
lo_speed_solid_mm_per_s=8
lo_speed_sparse_mm_per_s=10
hi_speed_perim_mm_per_s=55
hi_speed_loops_mm_per_s=110
hi_speed_solid_mm_per_s=80
hi_speed_sparse_mm_per_s=110
top_raft_speed_mm_per_s=20
bottom_raft_speed_mm_per_s=10
ext_gain_1=1
ext_1_mat_name=PVA
ext_axis_1=0
ext_gain_2=1
ext_2_mat_name=PLA
ext_axis_2=0
ext_Xoff_2=0
ext_Yoff_2=0
ext_gain_3=1
ext_3_mat_name=PLA
ext_axis_3=0
ext_Xoff_3=0
ext_Yoff_3=0
ext_gain_4=1
ext_4_mat_name=PLA
ext_axis_4=0
ext_Xoff_4=0
ext_Yoff_4=0
heat_time_coef_1=0.0015
nozzle_dia_1=0.4
nozzle_len_1=0.6
drive_len_1=700
heat_time_coef_2=0.0015
nozzle_dia_2=0.4
nozzle_len_2=0.6
drive_len_2=700
heat_time_coef_3=0.0015
nozzle_dia_3=0.4
nozzle_len_3=0.6
drive_len_3=700
heat_time_coef_4=0.0015
nozzle_dia_4=0.4
nozzle_len_4=0.6
drive_len_4=700
model_ext=1
support_ext=0
support_body_ext=0
raft_ext=0
ext_order_optimize=0
solid_loop_overlap_fraction=0.1
min_seg_len_mm=0
z_step_mm=0
max_nodes_per_s=0
profile_date=2018-02-09 17:45:29
