First layer override
TIQA
Post by TIQA »
hello.
first of all, thank you developers for this fine slicer. i just switched to this from s3d, but....
there are couple of issues:
most troubling for me is that first layer is only minimum not forced. i print 99% of time with petg, and its quite a diva in regards of first layer. best first layer for me is 0.2mm, more than that and it wont stick, less than 0.2 and it develops elephant foot. if i use dynamic layer height, which i REALLY love, some times, depending on geometry, kisslicer deciedes to no go with my 1st layer setting and go with 0.3 or something else. why the F* it would do that? i thing first layer settings need to be enforced no matter what. is there a workaround?
Re: First layer override
First layer thickness is a Minimum value. If the calculated layer (using stepover) is higher then the higher value will be used.
You could add a feature request for this.
