Upper Raft Layer Height
Posted: 02 Jan 2018, 14:17
I am trying to print using a 1.2mm nozzle in my primary extruder and a 0.4mm nozzle in my support extruder. For the part I am setting a layer height of 0.8mm which is getting carried over and used in the upper layers of my raft (despite having all of the raft thicknesses set to 0.25mm)which obviously doesn't work well when using a 0.4mm nozzle. I believe this is a bug as the raft layer should be able to be explicitly defined I would think independent of the settings used for the part.
Edit: After invetigating further, I should specify that it is the interface layer that is getting the improper thickness, not the upper raft layer. So maybe the raft interface should be separate from the support/object interface?
