Sparse infill where not expected
Posted: 10 Dec 2017, 22:41
Greetings all-
I was watching Michael Hackney's tutorial on Perimeters and Loops and printed the 75mm test disc. The purpose is to get the first layer printed with the perimeter, loops and infill to see the effects of the settings. I decided to modify the disc by making it into an annulus so I could see the effects on a 'inside' surface and and print it faster. I imported it into 3D Builder and subtracted out a cylinder.
When I brought it into KISSlicer, a curious thing showed up- it identified some areas of 'sparse infill' around the inside perimeter, outside the perimeter, away from the infill.
Here is a screenshot- Here is a detail of the lower right quadrant, rotated to show more area:
What I don't understand is why these sections are getting flagged outside of the part boundary. If it was some sort of mathematical anomaly, I would expect it to show up in some sort of predictable geometric pattern where the infill intersects the perimeters or loops.
Sparse infill describes infill inside of a part right?
Best regards,
Dennis
Best regards,
Dennis
