Loop path bug
lubarb
Loop path bug
Post by lubarb »
Slicing the thingiverse spiral ornament https://www.thingiverse.com/thing:210741 I get spurious loop paths crossing the infill and the center hole at heights between 8 and 10 mm.
I'm slicing using kisslicer 1.6.2
I'm slicing with a layer height of 0.2
I've tried changing a few other settings (e.g. corners on the seam settings), with similar results. I checked the model with netfab, and it didn't show any apparent problems. This is the first model I've tried with kisslicer and the first time I've used netfab, so I certainly may have missed something.
frozen.rabbit
Re: Loop path bug
Post by frozen.rabbit »
Not a KS bug, bad model. The separate spirals intersect each other in that model. KS doesn't process dense intersecting elements very well.
lubarb
Re: Loop path bug
Post by lubarb »
Is there a way to check if this model is bad other than slicing and checking the resulting output? KS doesn't report it as bad on loading.
Again, I'm new to KS.
frozen.rabbit
Re: Loop path bug
I can't recommend repair software, I error check models with 3DSMax, which catches alot of errors, but it doesn't detect any on this model.
lubarb
Re: Loop path bug
Post by lubarb »
