I am trying to set up KISSLICER to use with my Reach printer. Currently I use Cura as my slicer but I am unhappy with how it does support. I have used KISSLICER in the past with a OneUP printer without issue. Unfortunately I cannot say the same with the Reach. The main issue is with the extruder. The problem is it seems to over extrude (a lot) on the first line then it starts pulling the back in roughly 15mm then pushing it back out the same amount as the X and Y position changes. The end result is a single 20mm long line and then it chewing up the filament in the extruder. I am sure I am missing information needed to diagnose the problem, so please feel free to let me know what you need. Would it help to draw up a small simple 2 layer cube and slice it in Cura and KISSLICER to compare the results? I have tried adjusting the Gain by running the below g code and measuring how much filament the extruder drive pushes out the tube. Setting it to 26 gave me 100mm of filament.
G0 F1500
G01 X10 Y10 E100
Here is a sample of the code KISSLICER is producing. (Minus the startup codes)
G1 X109.16 Y112.73 Z0.7 E0 F30000
G1 X109.16 Y112.73 Z0.45 E0 F210
G1 X90.08 Y112.73 E46.4091 F600
G1 X89.26 Y112.61 E2.0133
G1 X88.58 Y112.31 E1.7968
G1 X88.06 Y111.9 E1.6235
G1 X87.63 Y111.34 E1.7159
G1 X87.36 Y110.73 E1.6264
G1 X87.27 Y110.13 E1.4691
G1 X87.27 Y90.08 E48.7725
G1 X87.39 Y89.26 E2.0153
G1 X87.69 Y88.58 E1.7968
G1 X88.1 Y88.06 E1.6235
G1 X88.66 Y87.63 E1.7159
G1 X89.27 Y87.36 E1.6264
G1 X89.87 Y87.27 E1.4692
G1 X109.92 Y87.27 E48.7724
G1 X110.74 Y87.39 E2.0153
Reach printer setup issue
- mhackney
Re: Reach printer setup issue
Did you use the Wizards to create your Printer, Style, Material and Support profiles?
It's a bit difficult to diagnose issues without the full picture.
Can you please zip up a complete G-code file you have created and attach it to a post.
