locking in print speed
peopoly
Post by peopoly »
hi guys,
I am trying to set first layer print speed to be 5mm/s and the later layers print speed to 85mm/s. This is my set up screen:
My gode shows a first layer of speed 99mm/s and later layers has a speed close to 150mm/s.
Gcode:
https://drive.google.com/open?id=0Bzke6 ... HM1SUNVajA
Any suggestions?
Re: locking in print speed
There's a few reasons for this; need to determine which one...
Can you please upload your profile Project/Save Project As, zip up the project file and attach it to a post.
Thanks.
BTW. Welcome to the forum!
OK, no need for the project file, loaded from G-code.
First problem is that the layer thickness is greater than the extrusion width.
You have a minimum extrusion volume of 1mm^3/sec which will override any speed settings.
EDIT: basically, you have fixed your extrusion speed by setting the Min and Max flow volumes to the same value...
