Different profiles for different parts at the same time
Posted: 09 Sep 2017, 01:55
by woody3dp
I have 3 parts on the build platform and I would like to experiment different style and material profiles for each of them, but in one print (I don't want to print three times for the 3 profiles I want to experiment).
Is it possible and if yes how can I do it ?
Re: Different profiles for different parts at the same time
Posted: 09 Sep 2017, 02:19
by abecker
Michael Hackney created a short video showing this process,
http://www.sublimelayers.com/2017/09/ki ... 3-and.html.
Posted: 09 Sep 2017, 04:29
by woody3dp
thank you abecker,
that's awesome. Is it also possible to modify some parameters into material tab or other ones for example or is it limited to style only ?
Posted: 09 Sep 2017, 14:39
by lonesock
The only things that get "locked" are the paths' trajectories, thicknesses, and widths. Those things are only affected by the style and support profiles. Everything else (like which printer is selected, material settings like temperature or PreloadVE) is referenced during the G-code export process, and so uses whatever settings are selected at the time of export.
I'm glad you like the function!
