Tip wiping
Tip wiping
How do you change the extrude length prior to wiping? I want to extrude more filament before wiping the tip.
Re: Tip wiping
Hi, look into "Printer G-Code"/"Selecte New Extr. and warm", this line M55<EXT+1> P700 S80 make the extrusion before wiping, Increase P to make more extrusion, the S is the speed of the extrusion, dont set too high speed or the motor will click.boxsterjohn wrote:How do you change the extrude length prior to wiping? I want to extrude more filament before wiping the tip.
Re: Tip wiping
When I adjust the offset for the wiping stick correctly then the jet/hotend does not go far enough over the filament container. The jet/hotend is too close to the front of the filament container just behind the jet wiper.
Re: Tip wiping
Help please! I need help changing the purge location so that the tip is positioned over the filament catch container and still have the tip wiper working correctly.
Re: Tip wiping
boxsterjohn wrote:Help please! I need help changing the purge location so that the tip is positioned over the filament catch container and still have the tip wiper working correctly.
What's the problem with the Offset menu ? Normally if you change the value you can reach the desired position.
Re: Tip wiping
When I adjust the offset for the wiping stick correctly ( just touching the Jet Wipe) then the jet/hotend does not go far enough over the filament container. The jet/hotend is too close to the front of the filament container just behind the jet wiper (at the same location where the wiping stick was adjusted to. Just touching the Jet Wipe)
Re: Tip wiping
This is the way it's supposed to work into the Cubex FW.boxsterjohn wrote:When I adjust the offset for the wiping stick correctly ( just touching the Jet Wipe) then the jet/hotend does not go far enough over the filament container. The jet/hotend is too close to the front of the filament container just behind the jet wiper (at the same location where the wiping stick was adjusted to. Just touching the Jet Wipe)
The hotend purge just behind the jet wiper, the melted plastic creates a blob in this area, after the purge the hotend moves forward to the print area and the blob is supposed to stay in place.
At next extruder change the wiping sick is supposed to hit the old blob and make it fall into the trash bin.
But I was not happy with this system, very often the blob comes with the jet and stick to the part, you can find in internet some solutions to build your cleaner.
Re: Tip wiping
Giovanni,
How did you remedy your tip wipe issue?
Re: Tip wiping
I've built an electro-mechanical system, with a switch and a delayed relay, but is pretty complex to do, you can see it in action here :boxsterjohn wrote:Giovanni,
https://www.youtube.com/watch?v=lCmuWdlxsWY
You can try this, it's much more easy to do :
https://groups.google.com/forum/#!topic ... O5sF6mtEWE
