Yeah I'm still not sure what was going on there. Maybe it cause I homed first before the test, but don't think so.
I got the ooze, measured it, got the #'s I needed and moved on. Going to try the destring tuning wizard today.
Re: KISSlicer 1.6 Beta 4.3 is here! (UPDATED 2017-08-09)
Sorry for the lack of Linux builds, I was focusing on the machines my small circle of alpha testers use and just got lazy about building on all platforms. I'm almost ready for Release Candidate 1, and that one will be built for Linux as well.walker wrote:Hi,
many thanks for new releases but is there the reason the linux version is not still available? I'd like to test it and help with bugs but I am using linux and the last version is beta2.4(and latest version is beta4.3)
Thank you for your patience,
Re: KISSlicer 1.6 RC 1 is here! (UPDATED 2017-08-17)
Hi, everybody!
The Release Candidate it out!!! (Linux builds will have to be tomorrow, sorry!)
I would very much appreciate any testing you can do in the next week or so. I will be working on updating the website.
Here is the changelog:
2017-08-17 - v1.6 Release Candidate 1.0
* Finer delta extruder RPM for BfB/CubeX firmware.
* Added 'Breakaway' text to 'Soluble' in Support Profile wizard.
* Added brief instructions to PreloadVE Exp Wiz.
* Made wizard windows have a minimum size.
* Fixed a bug when forcing the defaults above current settings level.
* Changed Delete-Profile to only report failure if file exists but could not be deleted.
* Profile deleting can now handle non-ASCII filenames.
* Allow a settings-level without a default value.
* Updated settings level for all controls.
2017-08-16 - v1.6 Beta 5.4
* Changed settings levels names to Basic Intermediate Advanced.
* Updated settings assigned level, and default values.
* Can handle default value on text inputs (for #/% fields).
* Extruder map summary shows mapping on new line to preserve space.
* Extruder config added numbers to labels so they can be translated.
* make sure all text is translatable
* Infill / loop overlap set to full on sparse-adapting-to-solid infill.
* Unsupported thresholds varied, then returned to middle third.
* Remove unsupported flag if a path only had a tiny low-value segment.
* Adaptive layer thickness now decides whether to keep last division by
seeing which average layer thickness is closer to the
(min + max) / 2 layer thickness.
* Added some hints to the tuning wizard.
2017-08-15 - v1.6 Beta 5.3
* Unsupported paths now feather in from 33% (0 extra cooling) to 67% (full cooling).
* The prepare for path change message is now generated 20mm before path end.
2017-08-14 - v1.6 Beta 5.2
* Hopefully unsupported velocity and fan now works for BfB.
* Approximated Preload using additional destring on BfB.
* Blend fan speed to Cool as estimated layer time approached min layer time.
* Blends fan as a function of "how_unsupported", and modulates during unsupported segments.
* Blends speed down to cool flow rate as a function of "how_unsupported".
* New XY Gap split into interface and main support.
* XY Gaps now support % of Extruder Width.
* Put in some preliminary work on the "Lock Paths" PRO function.
* In Preload Exp Wiz, turn groups light red if critical values are <= 0.
* Warn if the printer is not set for Preload when tuning wizard selects PreloadVE as mode.
* Fixed some Tab Order issues.
* Checking if printer can Preload in Tuning Wizard.
* Cleaning up menus.
* Working on flagging 0-values in Preload Exp Wiz.
* Worked around the "Weird tiny segments near perimeter when using brim" bug.
* Only slow top raft interface layer if it's a different extruder from the raft.
* Raft interface layers now respect the first layer thickness limit.
* Make interface-on-raft layer unsupported (to slow it down).
* Only trigger actual dwell if at least 50% of the required min layer time remains.
* Changed the Material Profile Wizard's PreloadVE values.
2017-08-08 - v1.6 Beta 5.0
* "_restrict.ini" file in the KSPATH will be read in and set the Restrict Advanced Settings password
- EddyMI3D
Darn! just me have the K8200lonesock wrote:Hi, everybody!
Here is the changelog:...Code: Select all
2017-08-17 - v1.6 Release Candidate 1.0 ... * Added brief instructions to PreloadVE Exp Wiz. ...
But not for long - I'm about to order the i3 MK2s (original)
Eddy
Now, that's a very good idea. And as a free bonus, it comes with reduced shipping times!EddyMI3D wrote: But not for long - I'm about to order the i3 MK2s (original)
Eddy
You should also consider the MMU...
- EddyMI3D
Hello Peter,pjr wrote:...
it's on my list too
Eddy
Multi Material upgrade. Two or four filament via single nozzle. http://shop.prusa3d.com/en/printer-upgr ... grade.htmlhacker wrote:What's MMU?
Thanks. I thought "MM" is about multi material, but didn't come up with "U" And I also thought that original prusa comes multimaterial nowadays.pjr wrote:Multi Material upgrade. Two or four filament via single nozzle. http://shop.prusa3d.com/en/printer-upgr ... grade.htmlhacker wrote:What's MMU?
Re: KISSlicer 1.6 RC 1 is here! (UPDATED 2017-08-18)
Linux builds are up!
