Info Setting raft
Posted: 17 Jun 2016, 10:06
by alil2096
Hi, why when I activate the raft, if I have a layer of 0.2mm makes me a layer of 0.5mm raft ?
Thanks :D
Re: Info Setting raft
Posted: 20 Jun 2016, 07:36
by PeterSm
Hello
Because layer height of first printed layer is "your layer height" + "z gap parameter in Support / Object interface setting" + "Printer/Hardware/Bed Roughness parameter"
For the second layer it is just "your layer height" + "z gap parameter in Support / Object interface setting"
If You do not want gap between raft and object, You have to set Z Gap to zero.
If You want to use raft and also support, well You'd have to find compromise between object/support gap and raft/object gap. Unfortunately it is controlled by one parameter.
Cheers
Posted: 25 Jul 2016, 01:06
by alil2096
Thanks :D And sorry if i don't have answer before
