CubeX Extruder Motor Assembly issue
Posted: 02 Mar 2016, 10:14
I inherited a CubeX at work they want me to play with and see if I can get running.
Problem 1 is that someone has detected the circuit board from the back of the motor.
I have two screws for the board but if I screw them in some contacts on the board touch the metal axis of the motor. It doesn't sit right.
It looks like there should be some spacers between the back of the board and the screw holes on the motor to make the board level to the back of the motor and not have anything touching.
Can someone either upload a side picture of the circuit board and the motor and how they screw together or at least describe how the board attaches to the motor?
Thanks.
Thanks.
