As posted on the Craftunique forum, here the working profiles for CraftBot.
EDIT: I change the settings and upload this attachment according new findings!
http://www.craftunique.com/forums/view-thread/297
Bart
CraftBot profile Kisslicer
- funBart
- KIsslicer CraftBot 3.1.rar
- (821.5 KiB) Downloaded 555 times
Bart ter Haar
- funBart
Re: CraftBot profile Kisslicer
Admin: Is it possible to make a subsection "CraftBot" at the hardware specific section?
I assume everything about RepRap can be under the the subsection "RepMan".
Bart ter Haar
- funBart
A stl of the Build Platform for CraftBot.
Unpack the stl, place it in the Kisslicer directory and point at it under the Printer tab //Hardware // Browse to Bed stl Model.
Bart
Bart
- CraftBot STL only.rar
- (21.77 KiB) Downloaded 526 times
- funBart
Kisslicer profile used to print a dragon. Except the style tab, the other tabs only have the used profiles for this specific print.
I used 0.1mm layer height and 0.3mm infill and support, but that's a pro function, so the same but slower result is with 0.1mm layer set.
http://www.craftunique.com/forums/view-thread/331/#3579
Bart
Bart
- KIsslicer CraftBot 3.1 - dragon.rar
- (821.37 KiB) Downloaded 572 times
Bart ter Haar
Hi Bart, I finally registered me, I can think of a problem with my Craftbot and it is this that when will make the second loop to finish making a film, it seems that runs into the already Heche and makes a strange noise, do you has passed you know why you ?.
A greeting and thanks.
Hola Bart, por fin me pude registrar, me ocurre un problema con mi Craftbot y es el siguiente que cuando va a realizar el segundo loop para terminar de hacer una capa, parece que tropieza con la ya heche y hace un ruido extraño, ¿te ha pasado a tí?, sabes el motivo?.
Un saludo, y gracias.
- funBart
5 Silcer profiles PLA for the CraftBot: Craftware, Cura, Kisslicer, Simplify3D and Slic3R
- Slicer profiles PLA for CraftBot Craftware, Cura, Kisslicer, Simplify3D and Slic3R.rar
- (887.84 KiB) Downloaded 532 times
Bart ter Haar
in styles:
What is infill_density_denominator=4 and infill_st_oct_rnd=2?
in styles:
- funBart
Hi, the infill_density_denominator is referring to the amount of infill, the %.
It's translated into KS, as you are not free to pick any infill percentages, but the slider is more referring to a couple of infill % (100, 50, 25 etc) as well 'vase' and 'hollow' : so a value of 9 is 2.5% infill and a value of 4 is 25% infill, vase is 11.
and the infill_st_oct_rn is referring to the type of infill: three choices: straight, octagonal (0) and rounded (2)
Bart ter Haar
