Material in extruder 1 has only 15 Max speed, set to 50.jaydie wrote:Here are the INI file, Im not sure which BAK file is needed. is it the bfb.bak? If that is nothing was created or may be I don't know where to get it. I just include the po.bak.
Thanks so much for looking at it.
CUBEITMOD V6.05 Fatal Error.!
Re: CUBEITMOD V6.05 Fatal Error.!
Here is a BAK file, but this was generated with Cubeit491, I have the fatal error when I change to Cubeit605
- L Block(0).bfb.bak.zip
- (38.63 KiB) Downloaded 263 times
You didn't change the Max Speed, set Max Speed = 50 on ALL THE MATERIALS you selected for ALL the extruders even if you don't use the extruder during the print.jaydie wrote:Here is a BAK file, but this was generated with Cubeit491, I have the fatal error when I change to Cubeit605
Finally got v6.05 working. I downloaded the Kisslicer 2.22 and start as a new.
