Is there ANY guideline how to use the <MATL> token or any templates?
MATL mentioned but without description:
http://3ntr.eu/wp-content/uploads/2014/ ... 260814.pdf
Well, what I really want to do is to give my PVA material a lower speed.Davide Ardizzoia wrote:Anyway, I will be more than happy to put more information on this command... as long as you tell me what you precisely want to know.
ohh - I haven't noticed that the <MATL> belongs to a specific material which I have to check at the "material" section and enter the gCode at "G-code"Davide Ardizzoia wrote:That's easy.
Put the following line into your PVA MATL section
M220 S50 ...and this in your PLA section M220 S100
Then put the following line in your "Select Extruder" printer gcode section <MATL>
Now, all your PVA will printat 50% of KS speed.
Davide, this is very cool. I just used it to run my bed 20C hotter for the first couple layers and then reduced the bed temp for the rest of the print.Davide Ardizzoia wrote:That's easy.
M220 S50
M220 S100
<MATL>
