The Tip Is Not Printed
- ksh_germany
Re: The Tip Is Not Printed
Hi, have you tired to Set the oversample Resolution small er? (pro/Premium Feature) when you share the stl i can Try to find a solution.
Greetings from Germany
Beantworte fragen zu Kisslicer auf deutsch
- ksh_germany
So i tested, the only way i found is to layer that small unicorn on side. So horn will be printed.
i testet a slice with a 0.2 nozzle even there the tip wan't to be printed. Scaling changes nothing!
- ksh_germany
Yes yes you have to put IT on the side so tip will printed.
Or you put an 0.1 nozzle in your hotend.
